Finding the shortest route using Dijkstra's algorithm
7337
12-23-2014 04:09 PM
XanderBakker
Esri Esteemed Contributor
5 5 7,337
Last month a user mentioned the Dijkstra algorithm to determine the shortest path between two nodes in a network. My first reaction was to use Network Analyst instead, but to honor the essence of a previous useless post: Japanese visual multiplication with lines using arcpy and a dash of patriotism (Dijkstra was Dutch) made me look into this a little more.
I came across this post; Dijkstra's algorithm for shortest paths « Python recipes « ActiveState Code  and from this post I actually used the code from this one; Rebrained! » Blog Archive » Shortest Path – Python . Remember, basic skills for developing code are search, copy and paste
It is basically recursive code that will ultimately get you the route between two nodes on the network. What you need is a "graph". This is a nested dictionary that lists all the connections between the from and to nodes and the corresponding distances. To be able to use the code I need to convert my "network" into this graph format.
What you need is a network (a simple line featureclass), in which all intersections of lines consist of nodes. You will also need a point feature class containing the start and end point. These points should correspond with nodes of the network.This is the result:
I came up with the following code:
# Name:        dijkstra.py
# Purpose:     determine route
# Author:      xbakker
# Created:     02/12/2014
import arcpy
import sys
def main():
    # input featureclasses
    fc_red = r"D:\Xander\GeoNet\Dijkstra\fgdb\test.gdb\red"
    fc_stops = r"D:\Xander\GeoNet\Dijkstra\fgdb\test.gdb\stops2"
    # create line dictionary
    dct_lines = createLineDict(fc_red)
    # create node and inverted node dictionary
    dct_nodes = createNodes(dct_lines)
    # update line dictionary with nodes
    dct_lines_nodes = combineLinesAndNodes(dct_lines, dct_nodes)
    # create graph
    dct_graph = createGraph(dct_nodes, dct_lines_nodes)
    # determine the node of start and end of route
    node_start, node_end = getStartEndNodes(fc_stops, dct_nodes)
    # determine route
    result = shortestpath(dct_graph, node_start, node_end)
    # create line with the result
    dist = result[0]
    route = result[1]
    print "Resulting route    : {0}".format(route)
    print "Length of the route: {0}\n".format(dist)
    cnt = 0
    for node_id in route:
        cnt += 1
        print "{0}\t{1}\t{2}".format(cnt, dct_nodes[node_id][0], dct_nodes[node_id][1])
def createLineDict(fc):
    """Crear dict de lineas con datos relevantes"""
    #OBJECTID (line): length, (Xstart, Ystart), (Xend, Yend)
    dct_lines = {}
    flds = ("OID@", "SHAPE@", "SHAPE@LENGTH")
    dct_lines = {r[0]: [r[2], (r[1].firstPoint.X, r[1].firstPoint.Y),
                (r[1].lastPoint.X, r[1].lastPoint.Y)]
                for r in arcpy.da.SearchCursor(fc, flds)}
    return dct_lines
def createNodes(dct):
    """Crear dict de nodos"""
    node_format = "node_{0}"
    cnt = 0
    dct_nodes = {}
    dct_nodes_inv = {}
    for line in dct.values():
        start = line[1]
        if not start in dct_nodes.values():
            cnt += 1
            node_id = node_format.format(cnt)
            dct_nodes[node_id] = start
        end = line[2]
        if not end in dct_nodes.values():
            cnt += 1
            dct_nodes[node_id] = end
    return dct_nodes
def combineLinesAndNodes(dct_lines, dct_nodes):
    """Crear dict con lineas y codigo de nodos"""
    dct_lines_nodes = {}
    for oid, line in dct_lines.items():
        start = getNodeID(line[1], dct_nodes)
        end = getNodeID(line[2], dct_nodes)
        dct_lines_nodes[oid] = [line[0], start, end]
    return dct_lines_nodes
def getNodeID(pnt, dct_nodes):
    for node_id, coords in dct_nodes.items():
        if coords == pnt:
            return node_id
            break
def createGraph(dct_nodes, dct_lines_nodes):
    res = {}
    for node_id in dct_nodes.keys():
        links = {}
        nodes_start = [[line[2], line[0]] for line in dct_lines_nodes.values() if line[1] == node_id]
        for node in nodes_start:
            links[node[0]] = node[1]
        nodes_end = [[line[1], line[0]] for line in dct_lines_nodes.values() if line[2] == node_id]
        for node in nodes_end:
        res[node_id] = links
    return res
def getStartEndNodes(fc, dct_nodes):
    cnt = 0
    with arcpy.da.SearchCursor(fc, ("SHAPE@")) as curs:
        for row in curs:
            cnt += 1
            if cnt == 1:
                pnt = row[0].firstPoint
                node_start = (pnt.X, pnt.Y)
                node_start = getNodeID(node_start, dct_nodes)
            elif cnt == 2:
                pnt = row[0].lastPoint
                node_end = (pnt.X, pnt.Y)
                node_end = getNodeID(node_end, dct_nodes)
            else:
                break
    return node_start, node_end
def shortestpath(graph,start,end,visited=[],distances={},predecessors={}):
    """Find the shortest path between start and end nodes in a graph"""
    # we've found our end node, now find the path to it, and return
    if start==end:
        path=[]
        while end != None:
            path.append(end)
            end=predecessors.get(end,None)
        return distances[start], path[::-1]
    # detect if it's the first time through, set current distance to zero
    if not visited:
        distances[start]=0
    # process neighbors as per algorithm, keep track of predecessors
    for neighbor in graph[start]:
        if neighbor not in visited:
            neighbordist = distances.get(neighbor,sys.maxint)
            tentativedist = distances[start] + graph[start][neighbor]
            if tentativedist < neighbordist:
                distances[neighbor] = tentativedist
                predecessors[neighbor]=start
    # neighbors processed, now mark the current node as visited
    visited.append(start)
    # finds the closest unvisited node to the start
    unvisiteds = dict((k, distances.get(k,sys.maxint)) for k in graph if k not in visited)
    closestnode = min(unvisiteds, key=unvisiteds.get)
    # now we can take the closest node and recurse, making it current
    return shortestpath(graph,closestnode,end,visited,distances,predecessors)
if __name__ == '__main__':
    main()
Have fun!
5 Comments
DanPatterson_Retired
Great!!!! now you just need to get it to print diredtions   Good example of dictionaries, I will definitely use for teaching
XanderBakker
Please do! I'm sure you will be able to come up with some enhancements... If you do, please feed them back to the post.
PriyankaMehta
One of the most useful blogs that I came across. Thank you for posting it ! Can you please suggest some method of modifying this code for taking multiple source and multiple destination points.. similar to how the closest facility works.
XanderBakker
Thank you, that is most kind. First of all if you would like to implement this type of analysis in a production environment, I strongly suggest to look at the Network Analyst extension. But if you want to use this script, you can, although it will not be as stable or powerful as the extension, and will require some efforts to implement what you want and include some proper error handling.
If you have multiple sources and destinations, this code will not be optimal for it. It will require you to loop through sources and within that loop, loop through your destination too and hold track of the shortest route.
Changes should go on line 31 where you should define the loop (probably based on a start and destination fc) and in the def "getStartEndNodes"  (line 106) where you get the start (source) and end (destination) nodes.
Maybe you could apply some intelligence where you don't go through each combination but only the closest ones (although that may not provide the correct results).
PriyankaMehta
Thank you ! You are right about network analyst being a much powerful and stable extension for production environment. Its a good idea to use the closest facility (or 3-4 closest facilities) for reducing processing time and effort if I want to loop through all destination and sources (and avoid using the extension).  Thanks for your suggestion !
Best Regards
About the Author
Solution Engineer for the Utilities Sector @ Esri Colombia - Ecuador - Panamá sr GIS Advisor / Python - Arcpy developer / GIS analyst / technical project leader / lecturer and GeoNet moderator, focusing on innovations in the field of GIS. Specialties: ArcGIS, Python, ArcGIS Enterprise, ArcGIS Online, Arcade, Configurable Apps, WAB, Mobile Apps, Insights, Spatial Analysis, LiDAR / 3D Laser Scanning / Point Clouds. UNME http://nl.linkedin.com/in/xanderbakker/ http://www.slideshare.net/XanderBakker http://www.scribd.com/xbakker http://twitter.com/#!/XanderBakker
Labels
