Street layer to NENA NG911 Data Model Toolbox
1301
04-28-2017 10:10 AM
TimWitt2
MVP Alum
Hey everybody,
I have created a python toolbox (it was created in 10.3.1) which takes your street layer and transforms it into the upcoming NENA NG911 GIS Data Model.
Steps are as follows.
  •      I would suggest you create a new geodatabase and import a copy of your street centerline
  •      Open the tool and choose that street layer
  •      Match the NENA field with your corresponding field. If you don’t have a corresponding field, click on the NENA field and use the X to remove it. It will still create the NENA field but it will be empty.
  •      Once you have matched/deleted all fields, you are able to run it.
Limitations: You can’t have a field in your street layer that has the same name as one of the NENA fields. (To remove that limitation I will have to write a lot of if/else statements )
I am looking forward to your feedback!
Tim
