I'm working on setting up the incident map template/scripts provided by ESRI.
I have configured my script and things seemed to set up ok and my records are successfully geocoded. The problem is in the log file says "-- 0 records successfully appended to Database Connections\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService." Any ideas on how to fix this issue? Is there an issue using the provided scripts with a versioned database? Any help would be appreciated.
Here is a copy of the log file...
Run date: | 2015-09-30_16-29-00 |
User name: | blomas |
Incidents: | M:\BrianLomas\Public Safety\Calls For Service.csv |
Feature class: \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService
Locator: | M:\BrianLomas\CompositeLocator |
-- 4 records found in spreadsheet M:\BrianLomas\Public Safety\Calls For Service.csv.
Incidents summarized by CALLDATE | |
-- 2015-09-28 00:00:00 # Incidents: 4 |
16:29:01 Creating features...
16:29:01 Geocoding incidents...
-- 4 records successfully geocoded.
16:29:09 Appending incidents to \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService...
*** 4 records could not be appended to \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService.
These records have been copied to M:\BrianLomas\Public Safety\2015-09-30_16-29-00_NotAppended.csv.
-- 0 records successfully appended to \\arcgis-prodserv\arcgisserver\directories\arcresources\data\sde_ArcGISSDE_sql02.sde\ArcGISSDE.SDE.LawEnforcementOperations\ArcGISSDE.SDE.CallService.
16:29:15 Publishing incidents...
16:31:12 Completed
