Set QueryParameters.MaxFeatures and catch a exception
2290
06-06-2017 07:03 PM
xiaoguangyan
When I set QueryParameters.MaxFeatures  execute query then will catch a exception(Unable to complete operation.), but don't set it codes go well
Tags (1)
xiaoguangyan
I notice that some featureserver with different  Advanced Query Capabilities,some having all the Advanced Query Capabilities true supports can ServiceFeatureTable.QueryFeaturesAsync(QueryParameters parameters, QueryFeatureFields queryFeatureFields) with setting QueryParameters.MaxFeatures , does this Advanced Query Capabilities matters?
JenniferNery
Is `NAME` a field name in the service? If you use a name that does not exist on server you will get the same error:
For example, when if I mistyped with `NAM` for `NAME`: http://sampleserver6.arcgisonline.com/arcgis/rest/services/Notes/FeatureServer/0/query?where=NAM+LIK...
FeatureTable.Fields should be able to give you the name to use in your query, it includes the same metadata found on server (i.e. FieldType, Name, Alias, IsEditable, etc).
xiaoguangyan
Hi Jennifer
I do have the field "Name", I checked and  i did't mistyped either
Thanks for your detail reply
