Open an .sde file to get the connection my geodatabase
8208
11
06-09-2017 01:32 AM
ManelKEDDAR
Is there any possibility to get the connection to my geodatabase using the .sde file connection generated with arcCatalog ? i looked at the tutorial but there's only how to open a local geodatabase .can any one help me
thanks advanced
dotMorten_esri
Esri Notable Contributor
Editing of 3D objects is not supported, besides editing the Z values of points, lines and polygons.
ManelKEDDAR
Hi Jennifer,
I need to know more about the EnterpriseGeodatabaseWorkspace  , i actually have sqlServer database that contains about 59 feature classes and feature tables and relations so to access to thses data do i have to create (.mpk) so i will import all my feature classes on the ArcMap so i can use it as a service to create my EntrepriseGeodatabaseWorkspace using my .sde  or may be there's a way to use directly .sde without using the service  (.mpk) thanks for your answer
cheers
