MMPK: Bad Symbol Rotation
9244
23
07-06-2017 09:45 AM
MarkCederholm
Attached is a small MMPK, created in Pro 2.0, that demonstrates a bad symbol rotation in Runtime 100.1 [I don't recall seeing this issue in Pro 1.4.1/Runtime 100.0, but I may be wrong].
Here's how it appears imported into Pro:
And here's how it appears in Runtime:
PreetiMaske
We are currently working on solidifying the symbols with visual variables. I am hopeful issues like these will get resolved as part of that work. Sorry about the inconvenience.
I tested with your test data that workaround to use simple symbols continues to work with 100.6.
Also feel free to let us know if you have other test cases for symbology that aren't  working correctly.
Preeti
PreetiMaske
Hello Mark,
Just following up on your original issue in this post regarding Symbol Rotation not getting honored. This has been fixed in 100.7. Did you get a chance to try it out and remove any existing workarounds? The symbol rotation should be honored without any workarounds.
Please note, other issue in this post that you reported regarding cloning layer renderer stripping out definition expression and other properties still exists in 100.7.
Preeti
MarkCederholm
I've been busy on other projects, but I hope to check out all of my reported issues this month.
MarkCederholm
I took a quick look, and symbols look good without the workaround.  Thanks!
