I've got 2 MultilayerPointSymbols that I extracted from CIM Json. I want to merge the 2 symbols together so that the actSymbol is on top of the mapMarkerSymbol and the actSymbol has a Y offset so that it's pushed up a bit (that way it'll fit better).. But I don't see anyway to give it a yoffset?
In the picture below, you can see the motorcycle and the EyeDrop symbol. I want to push the motorcyle up a bit.
Code and Image Follows:
string cimJson = "{\"type\":\"CIMPointSymbol\",\"symbolLayers\":[{\"type\":\"CIMVectorMarker\",\"enable\":true,\"anchorPointUnits\":\"Relative\",\"dominantSizeAxis3D\":\"Z\",\"size\":24,\"billboardMode3D\":\"FaceNearPlane\",\"frame\":{\"xmin\":0,\"ymin\":0,\"xmax\":24,\"ymax\":24},\"markerGraphics\":[{\"type\":\"CIMMarkerGraphic\",\"geometry\":{\"rings\":[[[12,2],[14.92,5.69],[17.19,9.3],[17.98,10.91],[18.54,12.41],[18.89,13.77],[19,15],[18.97,15.63],[18.94,15.95],[18.88,16.27],[18.81,16.6],[18.73,16.93],[18.63,17.25],[18.51,17.58],[18.37,17.9],[18.22,18.22],[18.05,18.53],[17.86,18.83],[17.65,19.13],[17.43,19.41],[17.2,19.69],[16.95,19.95],[16.69,20.2],[16.41,20.43],[16.13,20.65],[15.83,20.86],[15.53,21.05],[15.22,21.22],[14.9,21.37],[14.58,21.51],[14.25,21.63],[13.93,21.73],[13.6,21.81],[13.27,21.88],[12.95,21.94],[12.63,21.97],[12.31,21.99],[12,22],[10.78,21.89],[9.61,21.58],[8.5,21.06],[7.5,20.36],[6.64,19.5],[5.94,18.5],[5.42,17.39],[5.11,16.22],[5,15],[5.11,13.77],[5.46,12.41],[6.02,10.91],[6.81,9.3],[9.08,5.69],[12,2]]]},\"symbol\":{\"type\":\"CIMPolygonSymbol\",\"symbolLayers\":[{\"type\":\"CIMSolidFill\",\"enable\":true,\"color\":[0,0,0,255]}],\"angleAlignment\":\"Map\"}}],\"scaleSymbolsProportionally\":true,\"respectFrame\":true,\"clippingPath\":{\"type\":\"CIMClippingPath\",\"clippingType\":\"Intersect\",\"path\":{\"rings\":[[[0,0],[24,0],[24,24],[0,24],[0,0]]]}}}],\"haloSize\":1,\"scaleX\":1,\"angleAlignment\":\"Display\"}";
string actJson = "{\"type\":\"CIMPointSymbol\",\"symbolLayers\":[{\"type\":\"CIMVectorMarker\",\"enable\":true,\"anchorPointUnits\":\"Relative\",\"dominantSizeAxis3D\":\"Z\",\"size\":11,\"billboardMode3D\":\"FaceNearPlane\",\"frame\":{\"xmin\":0.0,\"ymin\":0.0,\"xmax\":24.0,\"ymax\":24.0},\"markerGraphics\":[{\"type\":\"CIMMarkerGraphic\",\"geometry\":{\"rings\":[[[20.0,7.0],[19.24,7.15],[18.59,7.59],[18.15,8.24],[18.0,9.0],[18.15,9.76],[18.59,10.41],[19.24,10.85],[20.0,11.0],[20.76,10.85],[21.41,10.41],[21.85,9.76],[22.0,9.0],[21.85,8.24],[21.41,7.59],[20.76,7.15],[20.0,7.0]],[[4.0,7.0],[3.24,7.15],[2.59,7.59],[2.15,8.24],[2.0,9.0],[2.15,9.76],[2.59,10.41],[3.24,10.85],[4.0,11.0],[4.76,10.85],[5.41,10.41],[5.85,9.76],[6.0,9.0],[5.85,8.24],[5.41,7.59],[4.76,7.15],[4.0,7.0]],[[4.0,5.0],[5.53,5.3],[6.83,6.17],[7.7,7.47],[8.0,9.0],[10.0,7.0],[13.0,7.0],[16.5,13.1],[17.5,12.1],[16.88,11.49],[16.41,10.72],[16.1,9.87],[16.0,9.0],[16.3,7.47],[17.17,6.17],[18.47,5.3],[20.0,5.0],[21.53,5.3],[22.83,6.17],[23.7,7.47],[24.0,9.0],[23.7,10.53],[22.83,11.83],[21.53,12.7],[20.0,13.0],[19.5,12.9],[17.4,15.0],[20.0,15.0],[20.0,18.0],[16.3,16.1],[13.4,19.0],[9.0,19.0],[9.0,17.0],[12.6,17.0],[14.6,15.0],[11.0,15.0],[7.0,13.0],[5.0,15.0],[0.0,15.0],[0.0,13.0],[4.0,13.0],[2.47,12.7],[1.18,11.82],[0.3,10.53],[0.0,9.0],[0.3,7.47],[1.18,6.18],[2.47,5.3],[4.0,5.0]]]},\"symbol\":{\"type\":\"CIMPolygonSymbol\",\"symbolLayers\":[{\"type\":\"CIMSolidFill\",\"enable\":true,\"color\":[0,0,0,255]}],\"angleAlignment\":\"Map\"}}],\"scaleSymbolsProportionally\":true,\"respectFrame\":true,\"clippingPath\":{\"type\":\"CIMClippingPath\",\"clippingType\":\"Intersect\",\"path\":{\"rings\":[[[0.0,0.0],[24.0,0.0],[24.0,24.0],[0.0,24.0],[0.0,0.0]]]}}}],\"haloSize\":1,\"scaleX\":1,\"angleAlignment\":\"Display\"}";
var mapMarkerSymbol = Symbol.FromJson(cimJson) as MultilayerPointSymbol;
var actSymbol = Symbol.FromJson(actJson) as MultilayerPointSymbol;
IList<SymbolLayer> newSymbolLayers = new List<SymbolLayer>();
foreach (SymbolLayer lyr in mapMarkerSymbol.SymbolLayers)
newSymbolLayers.Add(lyr); //VectorMarkerSymbolLayer,
foreach (SymbolLayer lyr in actSym.SymbolLayers)
var finalSym = new MultilayerPointSymbol(newSymbolLayers);
