I can reproduce a Mac Catalyst Release publish failure in a clean .NET MAUI project when adding Esri.ArcGISRuntime.Maui 200.8.1.
A standard MAUI template publishes successfully for Mac Catalyst. However, after adding the ArcGIS package and initializing it with .UseArcGISRuntime(), the architecture-specific builds succeed but the final universal app merge fails.
Environment
ArcGIS Maps SDK for .NET MAUI: 200.8.1
Target: net10.0-maccatalyst
Machine: Apple Silicon MacBook Pro
Build command:
dotnet publish -f net10.0-maccatalyst -c Release
Steps to reproduce
Create a new MAUI project
dotnet new maui -n MauiApp1
cd MauiApp1
Publish Mac Catalyst Release
This succeeds.
Add ArcGIS NuGet package
<PackageReference Include="Esri.ArcGISRuntime.Maui" Version="200.8.1" />
Initialize ArcGIS in MauiProgram.cs
builder.UseArcGISRuntime();
Publish again
Result
Both architecture builds succeed:
maccatalyst-x64
maccatalyst-arm64
But the final universal bundle merge fails with:
Unable to merge the file
Contents/Frameworks/RuntimeCoreNet.framework/Versions/A/Resources/Info.plist
it's different between the input app bundles.
Investigation
Comparing the generated files shows different CFBundleIdentifier values inside RuntimeCoreNet.framework:
arm64
com.esri.ArcGISXamarinArm64
x64
com.esri.ArcGISXamarinSimx64
This difference appears to cause the universal Mac Catalyst bundle merge to fail.
Workaround
Publishing a single architecture works:
dotnet publish -f net10.0-maccatalyst -c Release -p:RuntimeIdentifier=maccatalyst-arm64
Question
Is this a known issue with the ArcGIS Maps SDK for .NET MAUI 200.8.1 packaging for Mac Catalyst?
Thanks.
