How to create Dictionary Renderer of your own ?
2475
8
01-28-2019 06:51 AM
VijitWadhwa
Is there any provision to create Dictionary Renderer of your own ?
I don't want to use the mil255d or any of the specifications provided. I want to create DictioaryRenderer of my own symbols. How can I achieve this ? Please anyone help with something ??
dotMorten_esri
Esri Notable Contributor
You'd use ArcGIS Pro to author the .stylex files: Styles—ArcGIS Pro | ArcGIS Desktop
VijitWadhwa
Yes I created the file using ArcPro , but I am not able to render it
automatically depending on the attribute values of feature as in case of
dictionary renderer. How can I achieve such kind of functionality ? I want
to create my own dictionary renderer and give attribute values to each
symbol so that it automatically gets rendered to the respective feature. ?
VijitWadhwa
Hi ,
The stylex created using symbols from ArcPro , works perfectly fine. My requirement is to use symbols from .svg files and use them in stylex file .
dotMorten_esri
ArcGIS Pro's symbol designer supports importing SVG files.
VijitWadhwa
Is there any link for documentation of the above symbol designer ? I am unable to find information about it ?
VijitWadhwa
Thanks
VijitWadhwa
I am able to add svg's in .stylex file , but when I try to use the symbols in arcgis runtime app, the symbols created from svg's do not get render but the symbols that were predefined in Arc Pro render successfully.
How should I resolve this ?
