How to change WPF control background to white?
4704
07-13-2015 04:28 PM
AnnaLambrechtsen
the background of the control is grey with grid lines, the client wants it to be white - how to change this? i've changed every background setting i can find to white, but no joy.
it is definitely the control background not the map service image backgrounds. if i change the bottom map service to JPG it is no longer is transparent and is white, but every time you pan you see the grey with grid lines until the new image draws, which the client doesn't like.
i'm using 100% dynamic map services, there is no tiled layer.
i've attached a couple of pictures of what it looks like - one raw, one with some green circles illustrating the grid lines i'm talking about.
FreddieGibson
Honored Contributor
Have you tried setting the GridColor of the MapView control's MapBackground to Transparent and the Color to White?
Before
After
FreddieGibson
Honored Contributor
Before
After
AnnaLambrechtsen
excellent thanks, that's exactly what i was looking for.
FaiyazKhan2
With ArcGis Runtime SDK version 100.0.0 you can do this using
<esri:MapView Name="myMapview" Map="{Binding Map, Source={StaticResource MapViewModel}}">
   <esri:MapView.BackgroundGrid>
      <esri:BackgroundGrid Color="White" GridLineColor="Transparent"/>
   </esri:MapView.BackgroundGrid>
</esri:MapView>
