GeoViewHolding > Magnifier > Release
1087
9
06-09-2025 04:36 PM
Labels (2)
JoeHershman
MVP Alum
If one does a GeoViewHolding on the map a magnifier pops up.  In FieldMaps that gets handled and implements the Dropped pin behavior.
I am trying to implement something similar but I cannot see what event is triggered after the magnifier appears and the user releases.  The SDK seems to already be implementing the behavior for the magnifier, but what event handler does one implement to capture the release
-Joe
GKmieliauskas
You can switch off magnifier and implement your workflow on GeoViewHolding. Code below:
                // In MainPage constructor
                mapView.InteractionOptions = new MapViewInteractionOptions()
                    IsMagnifierEnabled = false, // Disable magnifier.
JoeHershman
MVP Alum
I want the magnifier.  I want to be able to have the magnifier, let the user 'drop' at the location of the magnifier and somehow my app gets a notification that action (and location) occurred
-Joe
GKmieliauskas
There is possibility to use GeometryEditor which works with magnifier, but it has some requirements. More info in that thread.
JoeHershman
MVP Alum
I am looking at the swift SDK.  And it looks like swift has events that do not exist in .net.  Which would seem how Field Maps is able to handle these behaviors
-Joe
GKmieliauskas
Custom renderers could help you. The custom renderer approach allows you to use native controls and their features. By writing custom renderers, you can capture native touch events.
JoeHershman
MVP Alum
Not sure if that will give me what I need but I cannot seem to attach a handler to MapView
#if IOS
            .ConfigureMauiHandlers(handlers =>
                handlers.AddHandler<Esri.ArcGISRuntime.Maui.MapView, MyMapViewHandler>();
                handlers.AddHandler<ContentPage, ContentPageHandler>();
#endif
I have this added in but the MyMapViewHandler never connects
    public class MyMapViewHandler : Esri.ArcGISRuntime.Maui.Handlers.MapViewHandler
        protected MapView MapView => VirtualView as MapView;
        protected override void ConnectHandler(Esri.ArcGISRuntime.UI.Controls.MapView nativeView)
            base.ConnectHandler(nativeView);
            //Still do not see a long press on nativeView
-Joe
dotMorten_esri
Esri Notable Contributor
The events are provided by the underlying platform views. For .MAUI that could be done via the gesture recognizers but doesn't look like they currently expose a holding event. In the maps sdk, it's actually done at the lower native level (UIKit on iOS, View on Android and FrameworkElement on Windows), and relies on the holding event to start showing the magnifier, and the pointer-up for turning it off. So you'd need to use a combo of those two events for your scenario.
dotMorten_esri
oh wait I forgot we do expose the GeoViewHolding event already. You can use that to set a flag that the user is currently holding / magnifier is showing, then use the pointer-up event to drop the pin.
JoeHershman
MVP Alum
I think will do with the holding event and turn off magnifier.  With MAUI it seems one cannot get all the events to be able to move the magnifier and handle the release (get the location of the release).  Think maybe you need swift for doing that in iOS.
-Joe
