error 0x80040239 : Using the intersect method of ItopologicalOperator
3939
11-04-2014 02:52 AM
Enguerranddes_Vaux
I would like to intersect a polygon and a polyline to know if the polyline is in the polygon.
The code work but when i do it on more than 100 000 times in a for, there is this error :
System.Runtime.InteropServices.COMException (0x80040239): Exception de HRESULT : 0x80040239
        à ESRI.ArcGIS.Geometry.ITopologicalOperator.Intersect(IGeometry other, esriGeometryDimension resultDimension)
My code :
    ITopologicalOperator4 topoOperateur = secteurPsr.Shape as ITopologicalOperator4;
    topoOperateur.IsKnownSimple_2 = false;
    topoOperateur.Simplify();
    IGeometry geomPsr = currentPsr.Value.Shape;
    IPolyline polylinePsr = geomPsr as IPolyline;
    (geomPsr as ITopologicalOperator2).Simplify();
    IGeometry geomResult = null;
    try
        geomResult = topoOperateur.Intersect(geomPsr,esriGeometryDimension.esriGeometry1Dimension);
THX for any help
UDATE :
I found the solution thaks to : http://gis.stackexchange.com/questions/10974/arcobjects-memory-leak-in-ifeatureclass-search-only-on-...
Code correction :
ITopologicalOperator4 topoOperateur = ((IClone)secteurPsr.Shape).Clone() as ITopologicalOperator4;
                    geomResult = topoOperateur.Intersect(geomPsr, esriGeometryDimension.esriGeometry1Dimension);
     if (topoOperateur != null)
                        Marshal.FinalReleaseComObject(topoOperateur);
