Draw points within a shapefile
1452
05-21-2020 03:07 PM
Erick_CamiloMorris_Duarte
Hi, I've got a trouble, I need to draw points within a shapefile, spaced one point with other 800 mts, but all within the shape, any Idea? Or, how to get the points where the perimeters are in the shapefile, so I can manually add its within the shapefile.
Tags (3)
NathanCastle1
I recommend taking a look at ShapefileFeatureTable Class  and GeometryEngine.MoveGeodetic Method. Together, you should be able to use GeometryEngine to determine where to place the points, and use the feature table to edit the shapefile. You can also use GeometryEngine to determine if a point is contained by a polygon.
