Determining Interior rings of an Exterior Ring
4430
02-17-2015 03:57 AM
SalieghAziz
Hi there
I hope that this is the correct forum for this.
I am new to ArcGIS runtime for .net (10.2.4), busy converting our ArcObjects to the new framework.
In 1 of my scenaria, I'm need to determine which rings are interior to which exterior ring (when having a multi-part shape).
I guess I could convert each ring into a geometry, and determine its area to figure out if its an interior or exterior ring, and then use the GeometryEngine.Contains or GeometryEngine.Within.
Is there a simpler way to achieve my goal?
dotMorten_esri
Esri Notable Contributor
Currently that is the way to go, or determining the ring orientation (there's a simple algorithm you can use by finding the top-most vertex and check if the next one is to the left or right of it).
dotMorten_esri
SalieghAziz
Thanks for the quick reply Morten.
DominiqueBroux
Esri Frequent Contributor
Checking if the next point is to the left or to the right of your point P is not correct. You have to evaluate the sign of the angle (previous point, P, next point) (see curve orientation)
