Hello!
Is there a way to use the ArcGIS Indoors FloorManager class with traditional Map Services (i.e. not AGO/Portal web maps) in a WPF application that uses the .NET Maps SDK version 200.5?
We are in the process of getting ArcGIS Indoors up and running in our organization and in-house applications. We have successfully converted our floor plans and features into the Indoors data model. I was able to build a simple prototype floor picker control that uses the FloorManager class to change the visibility of the floor levels, but I could only get this to work using ArcGIS Online / Portal web map. However, I'm not having much luck getting this working with traditional Map Services (non-Portal items). The FloorManager object on the Map object is always null and I'm not sure how to initialize it. Would it help to add the floor-aware layers as operational layers to the map using FeatureLayers or FeatureCollectionLayers?
Thank you!
David
