Dear all,
I have set up a workflow in model builder, with several variables set as parameters.
Thus, for example the cell size of my initial raster (a parameter) is used for further calculations in SQL commands. Executing the model with the actual cell size put into the calculations manually by me works fine, whereas using "%CellSize%" produces an error.
Did anyone encounter a similar problem or has an idea for a solution? For the sake of user-friendliness it is vital that the variables function as parameters.
Thanks in advance.
