Updating the attribute of one table to another
990
10-24-2014 02:48 AM
MANESK
I ve two shapefiles. Cities and States...Two shapefiles doesn't have a common field to join..The task is to assign the corresponding city to the state.I can overlay those two shp files and merge the cities that fall within the  state manually.it seems to be a time consuming process.i need to automate the process.I tried it using model builder... But i cant proceed for joining the attributes of those shp files... Pls help
DanPatterson_Retired
Start with a spatial join  and see if that partially solves your problem
MANESK
Thanks..
