In Model builder  I would like to use a database as the selection mechanism for selecting attributes of a shape file
4017
02-20-2015 11:43 AM
BrianWade
In Model builder
I would like to use a database as the selection mechanism for selecting attributes within a shape file.
I have a US ZIP Code shape file with Region ID in the Attribute field.
I have a database (dbf) or Excel with 50 Region ID’s.
I would like to select all ZIP Codes within the Shape File by each Region ID listed in the Database and write out the selected features to a file with the Region ID as part of the output Shape file filename.
I could do this individually but would rather automate the process as the Zones will multiply in the future.
Help Much appreciated
Thanks
KishorGhatage
BrianWade
Good Morning Kishor
Thanks for replying to my selecting using table input question. I created a quick model using what I think your attempting to show me and it failed.
I assume, not being a regular model builder user, that my issue is in the select layer by Attribute portion of the model. How do I get the value out from the Iterate field values tool to
Be used as a valid expression into the select layer by attribute?
I linked the value as an expression  to the select Layer by Attribute tool but it appears that that’s where the model is breaking.
See attached clip below,
Any Help is appreciated
Thanks
Brian
