How to choose one facility with "find closest facilities" script tool in model builder?
564
11-27-2017 02:26 PM
fengchen1
I  use "find closest facilities" script tool to do network analysis and I have to use this tool in model builder. I want to choose only one point as facilities, which can be achieved when I use it just as a tool (click the point that you want to choose on the street network). But when I add this script tool in the model builder I cannot choose only one point because I should stop editing in using model builder.
Could you please tell me what should I do? Thank you so much.
DuncanHornby
MVP Notable Contributor
All geo-processing tools honour selections, select it before you run the model?
DanPatterson_Retired
If you don't want to select it manually, then you will have to incorporate a Select By Attribute in your model and query by the feature id
