arcpy.getparametersinfo() returning wrong set of parameters
2301
07-31-2014 09:47 AM
BakaryKoné
Hi everyone,
I'm creating a medium complex model (in Model Builder) in which i add different home made python script tools.
When i run the whole model, an exception is raised because for some reason, as one of my scripts gets the set of input parameters that where used for the preceding run script.
For example let say i have
Script1
S1Parameter1
S1Parameter2
S1Parameter3
Script2
S2Parameter1
S2Parameter2
The tool for Script1 is run, the output is collected and used in some process, and then tool for Script2 is run.
Well, script2 receives the set of parameters of Script1 (S1Parameter1, S1Parameter2, S1Parameter3) .....
If i try to get de parameters values from Sys.argv[], i can see the right parameters where sent (S2Parameter1, S2Parameter2).
But the arcpy.getparametersinfo() returns (S1Parameter1, S1Parameter2, S1Parameter3)
I'have seen in arcgis help  (ArcGIS Help 10.1)  that arcpy.getparametersinfo() can take the tool name as argument, but i tried all possible ways to set Tool_Name for my tool but could'nt find the right one.
So have someone got the same problem ?
and can someone tell me the right way to use the arcpy.getparametersinfo(tool_name) methode ?
