Why is my selection covering my labels?
4403
6
04-04-2016 01:34 PM
RobSmith
I have a map that I send to customers and when I select the parcel(s) of interest the labels for water mains and sewer mains get covered by the selection.  How can I stop this behavior?
Thanks
AdrianWelsh
MVP Honored Contributor
Hi Rob,
Can you specify more on what platform you are viewing this map (ArcGIS Online, Desktop, etc.)? And maybe post a screenshot as well?
RobSmith
Yes.  I am using ArcGIS Desktop 10.2.2.  The red boxes on the screen shot indicate the issue I am asking about.
JohnSobetzer
Honored Contributor
I think you can't avoid it if your selection symbology has a fill.  If it is just an outline, such as the default, you shouldn't see your labels blocked.  If you want to use a fill, you could make the selection, create a layer in your project from it, and then symbolize that selection layer however you wish.
RobSmith
Currently I am using an outline selection.  I think I have tried a "fill" in the past and experienced the same behavior.
AdrianWelsh
Have you tried doing to same tasks in ArcGIS Pro? I wonder if the same behavior exists.
RobSmith
I currently do not have ArcGIS Pro installed.
