Symbology Line Fill / Marker Fill for GRID Raster Data
4369
12-15-2014 12:15 PM
NilsRatnaweera
Hello Everybody,
I have a GRID Raster with 8 Bit Integer Cell Values ranging from 1 to 4. I would like to change the symbology using Line Fill and/or Marker Fill accessed via "Symbol Selector" -> "Edit Symbol" -> Type: Line Fill Symbol".
This doenst seem to work: The the values are simply filled with the color I chose the lines or points to be in. Is "Line Fill" simply not possible with GRID Raster data or am I doing something wrong?
Thanks in advance!
XanderBakker
Esri Esteemed Contributor
When symbolizing a raster only the cell colors can be defined.
You could convert your raster to polygons and apply the symbology you want.
XanderBakker
NilsRatnaweera
Thanks for the answer! It's kind of what I expected, I was just confused since the possibility of setting "line fill" was there in the first place..
