Set Schematic Root python?
832
02-05-2019 07:58 AM
TimDine
Is it possible to set the schematic root when generating or updating schematics using python?
I've found some mention of doing this using arcobjects, and it works nicely when I'm working with the schematic interactively in ArcMap.  The situation I have is I'm generating a schematic from a specific point somewhere in the middle of a circuit, it's the beginning of my trace downstream used for the schematic.  I'm using 'Hierarchical - Main Line', in this specific case it's putting a different device as the starting point at the far left of the diagram giving me a wonky result.
This schematic is a middle diagram between two other diagrams, this behavior makes it look weird if you line the generated diagrams up in a row and try to follow through UNLESS I mark the start of the trace as the root.  It's being done in an automated way for several hundred diagrams.
