Question on Dynamic Text on Date ?
1543
02-24-2017 08:34 AM
DEAF_PROBERT_68
Honored Contributor
My question to you is how do I prevent the date from open a mxd each day ? What I would like the date to preserved it when you last created the Map Layout.in mxd ? Each date was insert under ArcMap using the Dynamic Text and then use the Current Date.
For example, when you set up your project and create a Map Layout the day you created (ie 2/21/2017) ? So, the next day you open the same Map Layout and the Date changes to 2/22/2017 ? I would like to have the date to preserved to 2/21/2017 rather than 2/22/2017  ?
I do hope you know what I am trying to say here.
Thanks !
MichaelMiller2
Don't use dynamic text if you do not wish to have it updated.
AbdullahAnter
Honored Contributor
There is another date in dynamic text , maybe help you.
 Date Saved . it is not changed if you don't save your MXD after that.
But still Michael Miller suggest is better than that and more appropriate for your case.
