Hyperlinks in Pro attribute table
4177
03-31-2021 07:23 AM
JimWooten
Is it possible to insert a hyperlink in a Pro attribute table?  If so, would I create a "text" field.  Also, some hyperlinks are very long and I'm concerned about field length.  The client would like to have the link in the popup.  Thanks.
JoeBorgione
 I tried adding a link to an external document
Yes, the article is specific to adding a link to an attribute table, as you asked.  I'm not sure what you mean by an 'external' document. You can also add links to pop ups.
That should just about do it....
JoeBorgione
See: https://support.esri.com/en/technical-article/000018754
JimWooten
Thanks, Joe.  The article indicates adding a hyperlink in the attribute table can be inserted to point to an individual feature in a feature layer.  I tried adding a link to an external document (zoning map for a particular town in NJ) but it doesn't seem to work.  I'll keep trying.  Thanks for your help.
Jim
JoeBorgione
JimWooten
For example, can I add the following hyperlink in the Hyperlink field cell for West Cape May Borough:
West Cape May Borough Zoning Map
