e00 to Shapefile
6254
01-14-2011 10:06 AM
MathieuCain
Hello,
I have over a 100 e00 files which I would like to convert to shapefile.
I know I can enable ArcView 8x tools, use the Conversion Tools menu to individually "Import from Interchange File..." to a coverage, and then use the Feature Class to Feature Class tool (Conversion Tools > To Geodatabase) to convert to polygons, however this is extremely slow to do for each one. Is there an easier method to run them all in one go in Model Builder?
The next step would be to merge them all and dissolve.
Thanks in advance for your suggestions.
MathieuCain
Ok. While awaiting a reply, I converted all of the e00 files into coverages.
The remaining question is now how to create a batch for the Feature Class to Shapefile process that will convert all of my coverage polygons to shapefile polygons.
Since each coverage includes arc, label, polygon and tic files, of which only the polygon file is really being visually shown, how do I add the 100 or so into the batch without having to go into each on individually? (note: I have tried selecting all coverages in ArcCatalog; dragging them into ArcMap where they display the polygons; then dragging all the polygon layers from ArcMap into the Batch File's Input Features; however this only ends up inserting them all into a single row and results in an error I need a method of inserting them all as separate rows all in one go).
Thanks.
JohnSobetzer
Honored Contributor
You can right click on any tool and select batch to do multiple features at the same time.  Having said that the coverage to shapefile conversion is perhaps best done in ArcCatalog by selecting your coverages, right clicking on them, and choosing Feature Class to Shapefile (multiple).
MathieuCain
Thank you Johns. The right click > Export > To Shapefile (multiple) in ArcCatalog is an excellent neat trick I was not aware of. For reference though with regards to the Batch method, how would you advise adding all of the coverages into the input? When I tried dragging in the selected coverages, it would simply add them to one input record (instead of having each coverage to a separate record) and thus return an error. When I did it earlier I had to resort to adding each one individually to the batch which is painstakingly long for a large number of coverages.
JohnSobetzer
Honored Contributor
I see what you mean.  My experience with the batch method is that it often is much clumsier than I would like.  In many cases you can select a group and drag them into the input column and they will each get their own record.  But instead of having the output automatically fill in the output with the same name of the input (or a variation thereon), one either has to use the fill method on the first entry and then go back and manually change each succeeding, or one has to copy and paste from input to output.  What a waste.  In this case I couldn't even find a way to fill the inputs by a simple drag.  The best I could do was hit the + button repeatedly, and then drag input coverages into their own row one by one.  Very clumsy.
If you have access to Arcview 3x the XTools extension allows you to select multiple coverages and import them to shapefile.  That is an efficient batch.  Perhaps XTools Pro for ArcGIS has the same tool, and have it free, for you to use.
deleted-user-IR249IovB3CN
The Data Interoperability extension is the way to go as long as it is available to you. I was able to batch convert .e00 files to feature classes very quickly. This tool is much easier to use than the "Import from E00" tool in the Conversion Toolbox, although that works too, just clunkier. If the data interoperability toolset is not available to you and you must use the import from E00, be sure to include the extension .aep in the output data source field of the IMPORT71 window that opens upon executing the tool. It must be typed directly in the field not in the browse window when you are declaring the directory location. That hung me up for a while.
