Definition Query to find where first character = 'XYZ'
8175
02-06-2017 09:44 PM
BenVan_Kesteren1
Hi All,
Just wondering if there is an easy way in the Query Builder to create a definition Query where the attributes first character starts with X??
Just for an example, in the below screenshot how would one create a query to return all features where the Feature_Type starts with the letter 'Y'?? At this stage it would only show YARRAMBA CRES. and YARRUNGA.
I was thinking something like using LEFT(FEATURE_TYPE,1) = 'Y' but this is invalid, I am assuming there is some other easy way that I cannot think of at 5pm in the afternoon!
#sql#definition query.
Any suggestions?
FC_Basson
FEATURE_TYPE LIKE 'Y%'
OR
FEATURE_TYPE LIKE 'YAR%'
The % is used as a wildcard and can be placed behind or in front of the text you want to match
e.g. FEATURE_TYPE LIKE '%CRES'
FC_Basson
OR
BenVan_Kesteren1
I knew it was too close to finish time to be trying to think of something simple like that! haha
Thanks!
JayantaPoddar
Try this:
"FEATURE_TYPE" LIKE 'Y%'
Think Location
RichardFairhurst
The Like and wildcard expression is the easiest to use if you want to match a given portion of a set string.  However, there is a way to write code that is like your original approach, but the expression is not LEFT, it is SUBSTRING (at least for file geodatabases and shapefiles).  The basic syntax is:
SUBSTRING(string_exp FROM start FOR length)
So for your problem it would be:
SUBSTRING(FEATURE_TYPE FROM 1 FOR 1) = 'Y'
Your title suggested you wanted to find any string that began with X, Y or Z.  That could be done with this expression:
SUBSTRING(FEATURE_TYPE FROM 1 FOR 1) IN ('X', 'Y', 'Z')
