Data Driven Pages - Fixed Scale Locator Map with other data frame extent
3099
01-22-2012 11:05 AM
by Anonymous User
Not applicable
Original User: 69
Is this possible? I can fix the scale but not use the other data frames extent or I can use the other data frames extent and not fix the scale.
DavidBarnes
Not currently. I found this idea on the ideas site.
by Anonymous User
Not applicable
Original User: jbarrette
Do you need to do this within the Arcmap UI or would you be able to use arcpy/arcpy.mapping?  With scripting, you are able to change the extents and maintain whatever scale you need.
Jeff
by Anonymous User
Not applicable
Original User: 69
Yes I feared the answer would be arcpy/arcpy.mapping. I may need to learn arcpy/arcpy.mapping
