Coordinates for a place of interest
4183
11
02-22-2021 01:46 AM
A_n_d_r_e_a
Dear Community,
i want to search for some coordinates of my point of interest and create some point features there.
But its not possible theres is no function for this...and if I go on absolut xy its also not possible...
I uploaded it...please have a look!
Thanks forward!
Greetings,
Andrea
DanPatterson
MVP Esteemed Contributor
A_n_d_r_e_a
Yep, i have seen this already, but what if I have x,y coordinates for a point of interest? I`ve got points and i want to fix it in the map...
This just works if I set the points arbitrarly 😕
Greetings,
Andrea
DanPatterson
Ahhh... one method
Make XY Event Layer (Data Management)—ArcMap | Documentation (arcgis.com) if you have a table already.
If you have a spreadsheet, then the Excel to Table would produce the table, then you can make the points from that
... sort of retired...
A_n_d_r_e_a
What the **bleep**...its impossible to search for places with coordinates and convert them to points..
I try it with this Ablsolut xy but it doesn`t work, if I enter my coordinates than the point doesn`t move...
hmmm...
Greetings,
Andrea
DanPatterson
The coordinates have to be in the coordinate system of the map... at least in ArcGIS Pro.
That is probably why making a new featureclass is easier, if you have a basemap beneath,
or enter the coordinates into a table, and follow the XY event layer, but... make sure you define the coordinate system of your coordinates or they won't align with your map
A_n_d_r_e_a
Yep I try it now for 2 hours...it doesn`t work...I`ve got coordinates in Gaus Krueger...so I need a projected or? And for Germany ETRS89 or WGS84 ? hmmm i`m confused...sorry Dan 😕
Greetings,
Andrea
A_n_d_r_e_a
Hey Dan,
I try it for 5 hours now...its still not working...Im working with Gauss Krüger Coordinates (see in the picture)...so I need a Projected Coordinatesystem right? And I need a geographic? Right? My Geographic will be Bessel 84 on which my Gauss Krüger Coordinates are based on...
I really dont know what is wrong 😕
Desperate Greetings,
Andrea
A_n_d_r_e_a
Sorry I forgot the picture 😕
DanPatterson
Those are in projected coordinates, so you can make the "xy event" layer I was talking about in the previous post
