Add Frame Camera Aerial Imagery to Mosaic Dataset
5762
04-10-2015 06:35 AM
JonKwong
I am testing the new Frame Camera raster type in 10.3.
I have hundreds of image frames which I would like to add into the mosaic dataset.
I followed the steps in Aerial imagery raster types—Help | ArcGIS for Desktop to add Frame Camera raster type to a mosaic dataset.
I have all the required parameters, except for the affine transformation.
Cameras table:
OBJECTIDCAMERAIDFOCALLENGTHPRINCIPALXPRINCIPALY
1[0]35105.3-228.7-173.1
Frames table:
OBJECTIDCAMERAIDRASTERNAMEPERSPECTIVEXPERSPECTIVEYPERSPECTIVEZOMEGAPHIKAPPA
1[0]E:\Camera\v02\13927.jpg13927831777.825479666.28858.592-2.1175.33185.967
2[0]E:\Camera\v02\13928.jpg13928837640.434488811.201417.767-2.285-0.43191.297
3[0]E:\Camera\v02\13929.jpg13929837681.671489019.06428.51-0.2891.43388.995
This is the error message.
Messages
Executing: AddRastersToMosaicDataset E:\Camera\Mosaic.gdb\v02 "Frame Camera @ E:\Camera\Mosaic.gdb\v02\RasterType.OBJECTID=1" E:\Camera\Frame2.csv UPDATE_CELL_SIZES UPDATE_BOUNDARY NO_OVERVIEWS # 0 1500 # # SUBFOLDERS ALLOW_DUPLICATES NO_PYRAMIDS NO_STATISTICS NO_THUMBNAILS # NO_FORCE_SPATIAL_REFERENCE
Start Time: Fri Apr 10 18:16:51 2015
2015-04-10T18:16:56.695: Loading raster datasets
2015-04-10T18:16:58.974: Completed crawling 145 data source items. Added 145 mosaic dataset items.
2015-04-10T18:16:58.980: Synchronizing crawled data source items
2015-04-10T18:16:59.058: Synchronizing items associated with raster type instance 'Frame Camera' [ID: 1].
2015-04-10T18:16:59.082: Distributing mosaic dataset operation across 4 parallel instances on the specified host: [RS020].
2015-04-10T18:17:06.587: Error: 8004206c: Failures reported while processing specified command item. [101]
2015-04-10T18:17:06.591: Error: 80042019: Chained Error ID: 0X80042019
2015-04-10T18:17:06.594: Error: 80042019: Could not build mosaic dataset item. [ID: 101, URI: 'E:\Camera\Frame2.csv|101']
2015-04-10T18:17:06.597: Error: 80042086: The image-to-film affine transformation parameters in the FRAMES table is either missing or invalid.
2015-04-10T18:17:06.602: Error: 8004206c: Failures reported while processing specified command item. [102]
2015-04-10T18:17:06.607: Error: 80042019: Chained Error ID: 0X80042019
2015-04-10T18:17:06.610: Error: 80042019: Could not build mosaic dataset item. [ID: 102, URI: 'E:\Camera\Frame2.csv|102']
2015-04-10T18:17:06.614: Error: 80042086: The image-to-film affine transformation parameters in the FRAMES table is either missing or invalid.
How can I get the tool to ignore the affine transformation and just use the orientation parameters?
TRGTactical
Also having this Error on ArcGIS Pro 1.4 Ortho Mapping from Drone images.
AndriyTailwind
I have similar errors when trying to add images to mosaic data set as frame camera:
2021-03-26T01:00:57.727: Error: 8004206f: Could not initialize the mosaic dataset's parallel processing engine.
2021-03-26T01:00:57.728: Error: 80040213: Configuration RasterCommander.ImageServer can not be started.
Server Object instance creation failed on machine FUJIBEAR.
 Image Server is not supported with the current license.
2021-03-26T01:00:57.728: Error: 8004204b: Cannot synchronize mosaic dataset items associated with the specified raster type instance. [Name: Frame Camera; Instance ID: 8]
I was trying to put 0 (zero) or 100% for parallel processing environments as I saw in ESRI Community and other forums but without any results. When I assigning "100%" - I received the same errors, and if "zero" - I don't receive any errors, it finishing quickly, but a table with footprints is empty.
Andriy
Thom
In my case (ArcGIS Pro 3.2), the problem was that the PIXELSIZE attribute was missing in the cameras.csv table.
However, the error message says that there is a problem with the frames.csv table.
The documentation says that this is an optional attribute:
Cameras table schema—ArcGIS Pro | Documentation
