Hello Tech.
I'm working on a project that requires National level DEM data, and I'd like to thank ESRI for providing the imagery layer (https://www.arcgis.com/home/item.html?id=0383ba18906149e3bd2a0975a0afdb8e).
- For the most part, the extracted point values from the USGS raster and the ESRI imagery layer are very close. (Col 2 , Col 3 &Col 6)
- However, when I project those raster’s (WGS 1984 Web Mercator Auxiliary Sphere), the point value difference between projected raster’s from USGS and ESRI were significantly high. (Col 4, Col 5 & Col 7)
Shape * | Raster exported from USGS | Raster exported from ESRI_layer | USGS_Projected (WGS-1984) | ESRI_layer_Projected (WGS-1984) | Abs(Raster exported from USGS-Raster exported from ESRI_layer) | Abs(USGS_Projected (WGS-1984)-ESRI_layer_Projected (WGS-1984)) |
Point | 3071.917 | 3071.913 | 3032.042 | 3071.913 | 0.004 | 39.871 |
Point | 3268.988 | 3268.984 | 3297.935 | 3268.984 | 0.004 | 28.951 |
Point | 3496.321 | 3496.318 | 3488.198 | 3516.118 | 0.003 | 27.92 |
Point | 2501.627 | 2501.627 | 2527.583 | 2501.627 | 0 | 25.956 |
Point | 3253.484 | 3253.491 | 3246.843 | 3271.352 | 0.007 | 24.509 |
Point | 2932.126 | 2932.129 | 2932.126 | 2955.189 | 0.003 | 23.063 |
Point | 3088.094 | 3088.087 | 3088.094 | 3110.907 | 0.007 | 22.813 |
Point | 2760.626 | 2760.628 | 2789.526 | 2766.848 | 0.002 | 22.678 |
Point | 2647.81 | 2647.816 | 2625.496 | 2647.816 | 0.006 | 22.32 |
Point | 2546.791 | 2546.793 | 2568.551 | 2546.793 | 0.002 | 21.758 |
Point | 2973.761 | 2973.768 | 2955.436 | 2976.748 | 0.007 | 21.312 |
Point | 2899.172 | 2899.171 | 2910.918 | 2889.789 | 0.001 | 21.129 |
Point | 1535.169 | 1535.16 | 1535.169 | 1514.62 | 0.009 | 20.549 |
I tried various geographical transformations and resampling methods but received no improvement. What could be the cause of this, and how should I proceed?
Looking forward to hearing from You
