Link to local file in popup
1561
10-05-2023 01:50 PM
MonikaNicholsRDC
Hi does anybody have anything set up to allow the LocalMaps popup to have a link that opens a file on a local server?
I am aware that for security reasons, Microsoft Edge 76+ and Chrome impose a number of restrictions on file:// URLs, including forbidding navigation to file:// URLs from non-file:// URLs.
I am thinking having the files in a cloud storage would be an option but does anybody else have this requirement and use any other solution for this?
MichaelPrior
SharePoint works well in LocalMaps and we use it on most services. It is really simple to set up and you can use the layers attributes to populate the URL.
Michael Prior
MonikaNicholsRDC
Thanks Michael, our sharepoint is currently on prem and we don't have the option to have these particular files in sharepoint at the moment due to file size restrictions however we are moving to sharepoint online soon so this could be a good option then!
TristanMcHardie
We have the same problem. Our tentative solution, which we haven't implemented yet, is to serve those files alongside LocalMaps in IIS so that they're accessed over http://. The entire directory the files live in is able to be shared, which makes it easy to serve in IIS. Note this is internal only - we'd look at something different for external.
MonikaNicholsRDC
Thanks Tristan. This is for internal only for us too so I will check with IT about whether we can try this option.
