Transform a grid map into a contour map
6744
13
01-24-2016 04:28 PM
GoldenJiang
I want to transform this grid map below (polygon, 10 m*10 m) into a contour map and make it less spotty. Is it possible to achieve so?
The value field only contains 10, 20, 30, which represent my management classes (calculated from excel spreadsheet).
DarrenWiens2
See if this will work for you:
Original:
Point to Raster:
IDW:
JayantaPoddar
You could try Focal Statistics (Spatial Analyst extension is required).
How Focal Statistics works—Help | ArcGIS for Desktop
Think Location
DanPatterson_Retired
Jayanta... it won't help much with the chunkiness, that can slightly removed by converting to vector with generalize, then producing the raster at a finer grid cell size. then maybe focal stats to add in some edge randomization
NeilAyres
Use the cubic convolution renderer to smooth "blocky" rasters on-the-fly.
