Hi All,
I am trying to create a 1' curved strip in the parcel fabric but when I attempt to create the parcels it looks as if the curve collapses on itself. This happens both when trying to create a parallel offset and when try to create them from a join session. I can make one a 3' but any less, the process seems to fail. Are there any other type of cluster tolerance configurations that I can adjust for this?
Construction:
Results: The points are created and the end point lines are created but the 1' offset curve is not.
Works fine at a 3' offset:
Michael,
Try turning on parcel lines. Perhaps the problem actually lies in the Type code of the new parcel.
Worth a shot,
Jack
Jack Horton | Instructor | Esri | 360-754-4727 x8923 | jhorton@esri.com<mailto:jhorton@esri.com> | esri.com
I just tried to make a 1" curve parcel in my fabric and it worked just fine - Jack Horton is probably right about your parcel being incorrectly typed. If it's incorrectly typed or not typed at all you'll see the points but nothing else.
I figured it out. In the properties on the parcel fabric feature class, under Edit Environment -> Line Cartography -> Circular curve line fit tolerance, the radius was set to .8 Meters for some reason, I cranked it down to .1 and all is good.
Thanks!
