Help with joining parcels along a curve!
821
07-17-2019 09:35 AM
AnneBransford1
New Contributor III
https://imgur.com/LjpBqOQ
I’m running into an issue as I edit the parcel fabric that I could use some help with. I need to join two parcels along a curve but I have a gap I can’t figure out how to get rid of (green circle). The parcels have the same radius and I’ve joined their radial points (red circle). If I could join a point to a curved line my problem would be solved, but I can’t. Maybe this is a simple thing that I’ll feel embarrassed about asking, or maybe there’s a trick I just haven’t learned yet. Does anyone know anything that could help me out here?
AnneBransford1
New Contributor III
That definitely solved my problem, thank you!
It makes me think though that there's got to be a better way for ArcMap to handle situations like that. While my issue isn't exactly a common situation, it's quite predictable that it will occur on some of the plats that my office receives. Do other people not have this issue? Does everyone just use the Regenerate Fabric tool as a workaround? Is there something better in Pro?
