I would like to set a default for the Historic Parcel Reason Retired field. 99% of the tax parcels I retire get the same code, and it would be nice to set this property somewhere. Is that an option? I can't find it, so I'm reaching out.
Jamie, we are working on an update to the Attribute Assistant so that it will work with Parcel Fabric edit events. Previously attribute assistant rules only worked on fabrics by manually running them on a parcel selection.
Once these attribute assistant add-in enhancements are available, they should help you with this task. We did a demonstration of it at today's Land Records meetup, using your question as an example. If you want to take a look, the meetings are recorded; today's recording will be available in the next week or so from http://bit.ly/1BBAerr (You need to be logged in to get the recordings)
Stay tuned!
-Tim
Stay tuned!
-Tim
