I am bringing in a couple of parcels that were COGOed based on a Record of Survey (from a Lot Line Adjustment). Is there a way for a line segment to adopt the COGOed bearings from surveyed lines on an adjacent parcel in the Parcel Fabric?
Hi Michelle
A parcel line cannot automatically adopt the cogo bearing of an adjacent line in the parcel fabric - there isnt any way to do this short of opening and editing the parcel.
Christine, Thank you for the comment to my post. I was indeed looking for a shortcut. I suspected that the only way was to open the adjacent parcel and recogo. I am also thinking that if the new parcel overlaps the adjacent parcel; you can do the parcel remainder – this would grab the new COGOed values without opening the adjacent parcel(s) and reCOGOing. However, the 'parcel remainder' method only works if the parcels overlap - that may not happen often with a simple lot line adjustment.
I appreciate your help!
There is a workflow in the documentation for a lot line adjustment - it uses the Construct from parent tool. It might be helpful:
