How to debug requests to the portal server?
822
07-19-2023 01:20 AM
padmalcom
Hi, since we frequently run into errors communicating with our portal server using the Portal and PortalItem classes, I'd like to know if I can output the requests and responses to/from the portal server somehow.
GuntherHeppner
@padmalcom
With the Maps SDK for Kotlin v200.1.0, there is no way to log or observe the network traffic. You can observe network traffic with a Web Debugging Proxy such as Charles or Fiddler though.
With the upcoming 200.2.0 release we will provide an API that allows you to intercept network requests, so you would be able to observe/debug/log your portal requests programmatically.
GuntherHeppner
@padmalcom
padmalcom
Thanks for the fast answer @GuntherHeppner
