Download File Size Estimation is Wrong
1007
08-14-2023 02:14 PM
NikkKarataev
Hi! I am currently working on downloading maps for offline use and am utilizing the tile-cache-size-job to estimate the size (EstimateTileCacheSizeResult)
However, even though I've applied the UseReducedFontsService, the final vtpk file size is still larger than expected. The estimated size is 3180866 bytes, but the actual vtpk file is 24MB.
Is there a more accurate way to calculate the size, or am I possibly using the wrong method?
Thank you
Nicholas-Furness
The EstimateTileCacheSizeJob only works on image tile services. Vector Tile Services do not support an estimate operation.
Are you sure you are calling EstimateTileCacheSizeJob on the vector tile service to get your number of 3180866? That should fail.
