ArcGIS Maps SDK for Java headless
1480
10-31-2023 12:13 PM
EricDurbin
Is it possible to run the ArcGIS Maps SDK for Java and or JavaFX in a headless/sever environment or do I need a desktop with a display and graphics card? If so are there any examples of doing this?
MarkBaird
Hi @EricDurbin
An app you create doesn't have to display a map in a UI, there is lots of functionality in the API which will work headless and I've recently written examples of applications which run on a Raspberry Pi for collecting sensor data for example (beta release for Arm Linux).
It would be helpful if you could tell me a little more about what you are doing.  The license agreement for the Maps SDKs doesn't typically allow you to put the API behind a Spring micro service for example - its an API aimed at desktop applications.
If you give me a little more information about what you are trying to achieve, we can guide you to a good solution.
Thanks
Mark
EricDurbin
That is similar to what I was hoping to accomplish.  I wasn't aware of that stipulation in the license agreement and can't seem to find it. Can you point me to that please?
MarkBaird
This page talks about using the Maps SDK in a service.
I think the best approach to help you, is if you can give some details on what you are trying to achieve and we can guide you to a good solution.
