Can you clip a MrSID file in arcmap?
1466
15
01-10-2019 08:08 AM
BrandonPrice1
New Contributor III
I am tried to clip the MrSid image highlighted in the table of contents using the export data option and the clip (data management) tool and neither work. The export data option is not there when you right click on the sid layer in the table of contents and the sid layer does not even show up in the clip tool as a potential layer to clip. Can someone please advise? Thanks.
GIS
ArcGIS Pro
CodyBenkelman
Brandon
I don't understand why this isn't working.  It works on my computer, although I do see in your screenshot that the *sid file is not offered as an available input.
the Help doc here Clip—Help | ArcGIS Desktop  confirms it shouldn't be a licensing problem (I have ArcMap Advanced, thought you might have Basic) so it should work.
Note instead of running the GP tool, you can do a clip using the Image Analysis window (IAW).
Note that the clipped image from IAW is virtual, on screen only, so then you'd need to Export (right click in table of contents) and Save As, noting that you can't write out *.sid files in ArcMap, so you'd have to save a TIFF or other format.  (By default it tries to write a raster into a database, so you may want to change this to a file path and then end filename with *.tif).
Also, in the Export step it may try to promote your data to 16 bit and set NoData value to 256, so I assume you'd want to set this value to 0.
defaults shown:
change these fields:
George_Thompson
Esri Frequent Contributor
You may need to export/copy the MrSID to a different format then clip the raster. This could be done via a model or Python.
MrSID is a "read-only" within ArcGIS:
List of supported raster and image data formats—Help | ArcGIS Desktop
Supported raster dataset file formats—Help | ArcGIS Desktop
--- George T.
BrandonPrice1
New Contributor III
Thanks George. I am using the copy raster in arccatalog suggested from your other thread: https://community.esri.com/message/379970?commentID=379970#comment-379970 . I get errors:
Any advice?
DanPatterson_Retired
MVP Esteemed Contributor
Your destination folder is quite long and unwieldy and contains spaces in the path etc.
Try a local simple folder to get the process working
And! make sure you specify a file extension.  *.tif files are the recommended raster format, so
C:/test/test.tif
would be a good candidate name for the export.
If you don't specify an appropriate file extension, your paths will cause esri grid formats to fail.
BrandonPrice1
New Contributor III
so far so good. still processing.
CodyBenkelman
Brandon
defaults shown:
ultiresolution Seamless Image Database (MrSID)
A proprietary compression technique especially for maintaining the quality of large images. Allows for a high compression ratio and fast access to large amounts of data at any scale. The MrSID Encoder is developed and supported by LizardTech, Inc.LizardTech website
Supports generations 2, 3, and 4.
Single file—extension *.sid
World file—extension *.sdw
Read-only
8- and 16-bit unsigned integer
Yes
Generation 2 and generation 3—limited to 1 or 3 bands
Generation 4—unlimited
Read only.. isn't correct then
So Raster file formats—ArcGIS Pro | ArcGIS Desktop
the above is only partially correct or is there more offered if you have the Data Interoperability extension?
BrandonPrice1
New Contributor III
I will definitely try this method Monday if the copyraster never completed because I left the process to run over the weekend.  This makes sense that it would be much faster. I will keep this in mind for the future.  Thanks Cody.
BrandonPrice1
New Contributor III
I still cannot save to another format by doing a right click sand save as for the sid file in the table of contents. I also do not know how to specify how to clip the image using selected polygons in the image analysis window. View screen:
CodyBenkelman
Brandon
Help is here Using the Clip button on the Image Analysis window—Help | ArcGIS Desktop  and I showed the UI's above for clipping.  What happens when you try that?  Error?  Nothing?
as for saving, Right click in table of contents (select the new layer after clip) to Export / Save As should also work to save a *.tif image copy of the *.sid image.   Help is here Exporting a raster in ArcMap—Help | ArcGIS Desktop
If these are not working, please log a support incident with Technical Support
https://support.esri.com/en/contact-tech-support
It looks like you have 1,000 polygons.  Are you intending to clip out 1,000 separate tiny image in separate files?  Or are you expecting to create one single image with 1,000 "islands" but remove all the pixels in between?
Clipping from the Image Analysis Window (IAW) will do the latter; if you want the former, you'd have to use a GP tool or Python to select and clip one at a time, but I have a feeling there must be a better way to reach your end goal.  If you put your *.sid file into a mosaic dataset and use your polygons to define the Footprint, then set mosaic dataset properties to "Clip to footprint? = Yes" you'll get 1,000 islands with no pixels in between.  If your subsequent processes are in ArcMap this should work, but if you're trying to export to some other software, it won't understand the mosaic dataset.  Can you let us know what you're seeking to accomplish?
Cody
