Dynamically load ArcGIS online modules
1884
08-10-2019 10:07 AM
WilliamFerster
It is possible to dynamically decide which models to require()?
It takes a while to load a bunch of widgets, using the JavaScript require() function, so I want to be able to only include the ones I'm using in any given instance to the ones I'm using.
Currently, I do this:
var reqs="esri/Map""esri/WebMap", ... "esri/widgets/Legend";
require(reqs, function(Map, WebMap, ... ,Legend,) {
It's easy enough to fill the reqs array, but how can I vary the names in the function?
KenBuja
MVP Esteemed Contributor
Have you considered loading the modules only when you need them? In her blog posting about code snippets, Raluca Nicola‌ uses this syntax:
const view = require("esri/views/View").views.getItemAt(0);
WilliamFerster
Came up with a solution. Not as elegant as one would like (i.e. having to spec the class names directly), but it works.
var reqs="esri/Map", "esri/WebMap", ... "esri/widgets/Legend";
require(app.reqs, function()
      var Map, WebMap, MapView, SceneView, KMLLayer,  ...  Legend;
      for (i=0;i<app.reqs.length;++i) {
      key=app.reqs[i].match(/([^\/]+)$/i)[1];
      if (key == "Map")          Map=arguments[i];
      else if (key == "WebMap")  WebMap=arguments[i];
     else if (key == "Legend")  Legend=arguments[i];
KenBuja
