Why don't these data appear in the right place?
818
02-13-2015 10:01 AM
DarrenWiens2
0 0 818
This question almost always boils down to knowing the difference between Defining a Projection and Projecting Data.
  • Define Projection
    • Your data was created using some coordinate system. The data itself knows those coordinates, however, the file may not know what coordinate system it is supposed to use. Use Define Projection to tell the data (which, in turn, tells ArcMap) what coordinate system to use.
    • Define Projection is used to assign a known coordinate system to an unknown coordinate system.
  • Project
    • If you want to switch projections for some reason (e.g. to lessen certain inherent projection-specific bias), use the Project tool.
    • Project is used to assign a different known coordinate system to data (that has a known coordinate system)
