Three ways to prepare your data for Voxel Layer
Hello everyone! The new blog on how to make your netCDF data compatible to the Voxel Layer is out!
Percentages of geological settings per catchment
I have two .shp files 1) Is a whole country that is divided into different geological settings and 2) a catchment (a polygon) that is withing this country and covers at least 3 of these geological settings. What I would like to do is to find out which ArcTool could help me to find out the percentages of these geological…
digitizing work flow
What is the best workflow practice for digitizing lines and polygons? I am thinking of digitizing lines first in a couple of layers, then forming polygons by manually selecting lines. Would this approach work if I want to generate a polygon from two separate layers? Thanks
Geological GIS Analyst?
Hey Guys, I have been given the opportunity to describe a job title for an employee that is a geologist by education but has become the geospatial expert and permitting expert within our team for the past two years. Does anyone know of a good job title that encompasses both of these skills? Thanks in advance
Looking for Arcgis Tutorial data for Desktop
Good tutorial in the "help" feature but need the map packages. "exercise 1a: Creating new points" An aerial photograph of Zion National Park is supposed to be used but I don't see the map packages anywhere.
How can i create a geotiff that includes the overlaying shape files?
I need to create a geotiff that includes aerial imagery and mapped featureclass polygons. I have access to 3d and spatial analyst but have not been able to find what I need. Any suggestions?
How can I correctly label my units after a polygon from lines using point feature class attribution in Arcmap Pro?
I used to use the workflow create feature class from lines and populate my polygons with subtypes from a point feature class with ArcMap 10. I have just moved to Arcmap Pro, and have used the replacement workflow of Polygons from Lines which allows for the creation of labels generated from the point feature class but does…
How can I achieve Unit subtype attribution from point features?
Problem converting LiDar LAZ files to LAS files
I am trying to convert a group of files and I followed the directions posted here: https://support.esri.com/en/technical-article/000018224. At the end of the conversion I get the following message: File 'C:\Users\gnewp\AppData\Local\Safe Software\Interoperability\ArcMap-20190416-213912\fmetool-a15148.fmw' does not exist.…
Error in cell statistics while using Shadow slope Algorithm
Hi! I'm a student and pretty new to ArcMap and GIS overall so this is my first post here. I'm mapping an area for potential landslides and using the tool Shadow Slope Algorithm (F. Lindberg et al (2011)) to see potential soil failures. I have done som work with this algorithm before and it worked fine. This time it wont…
How to create a vertical interpolated surface?
I'm not sure if I am just using the available tools incorrectly or there currently is no tool available that can solve my problem, but I will try to explain my problem the best I can; So I have performed an ERT servery to acquire various resistivity values at depth along a straight survey line. I have a point file along…
How to export point features [xy data] symbol into line features [strike/dip]?
HI, I've been using ArcGIS to create Geological Map with Strike/Dip symbol in it. In ArcGIS, to create that symbol, we just had to import XY Coordinates (Point Features) and change the symbology into Strike/Dip [ESRI Geology]. I like to use ArcGIS for making geological map because ArcGIS can rotate the all data…
GIS/Geoscience Conferences?
Hey All, Wondering if anyone can give any suggestions to any worth while conferences that focus on GIS in applications of Geoscience? Domestic or international.
BGS Geology of Britain
This might be of interest to users of Geology data! 3D geology map from British Geological Survey using the Esri platform! Explore the app here: Geology of Britain What do you think?
Is there a complete fgdc-std-013-2006 style package?
The ESRI Geology 24k styles is an incomplete set of Geologic symbology based on the fgdc-std-013-2006 standard. Does anyone have a complete set of symbology based on this standard in a ArcMap 10.1 style file? If not what is the easiest way to edit or modify existing symbols for lithologic textures? Thanks.
Survey on the use of Technology in Geology Education
Dear Colleagues, Apologies for cross-posting. We would kindly like to invite lecturers to participate in a short survey on the use of technology in geology education. The survey can be accessed here and will be available until Saturday the 30th of September 2017 at 00:00 GMT. The goal of this survey is to investigate…
Ensuring that Personal and File Geodatabases are kept in sync when updated daily?
down votefavorite We wish to link an ESRI geodatabase to an ‘.mdb’ database. The ‘mdb’ database is updated daily. We would like to make sure that the ‘.gdb’ is up to date whenever updates are made to the ‘.mdb’. We wish to use this ‘.gdb’ as a template for ARCMap workspaces, where all the geoscientists have access to…
We wish to link an ESRI geodatabase to a ‘.mdb’ database. The ‘mdb’ database is updated daily. We would like to make sure that the GDB is up to date whenever updates are made to the ‘.mdb’.
The database is created from ‘Acquire’, and is exported in ‘.mdb’ format. We wish to use this ‘.gbd’ as a template for ARCMap workspaces, where all the geoscientists have access to up-to-date information. Currently many geoscientists in the organization have out-of-date files they are using on their personal machines.…
Microsoft Surface (2017 Model) with ArcMap for Multi-GB Datasets and Mapping?
I've looked at past discussions on here for Microsoft Surface compatibility with ArcMap and there seems to be mixed results almost entirely based on what you want to do. So I will first describe what I do: I almost exclusively work in ArcMap, displaying multi-GB planetary datasets (basemaps and DTMs) anywhere from a few…
TIPS USE FILE netcdf WITH IMAGES Landsat, GEOLOGY AND OTHER PARAMETERS
Hello everyone, I'm a Geologist / GIS analyst and I'm finishing an internship in a company computer engineering. I was asked to follow and try to carry out a project that concerns the use of the file NetCDF (Network Common Data Form, is a set of software libraries and data formats that are self-describing,…
How to detect/select/identify island polygons
I am generalizing geological maps and as a part of the process I am dealing with "Island Polygons". For that, I first need to identify them or select them. I already tried: Select by Location, by creating another layer from the same layer and used intersect the source layer, which select not only island polygons but…
Force high resolution basemap
I'm working at a scale of 1:2,350,000 and the output is for publication. I'd like to include a basemap but at this scale the resolution of the basemap (world imagery) is fairly poor. As a workaround I'm having to zoom into portions of the map and then export to third party imaging software to stitch the outputs together.…
change lenght rectangle
Hi, I've rectangle and I want them to have a new lenght. the lenght is in the attribut table. is it possible ? For exemple the actual lenght is 120cm and I want them to be 150cm.
How calculate the length and wide of a rectangle (shape)
I have a shape file witch is a rectangle and I want to calculate the length of the side of this rectangle.
geological cross section
HI everybody, I have a soil classification (raster ans shapefile), and topographic cross section made from a DEM. I would like to ''colorize'' the cross section depending on the classification. to summarize I want to visualize on the cross section the soil occupation. is it possible ? Many thanks Maxime G.
