XY to Line generated incorrect output
601
05-02-2021 01:02 PM
HarryHattusa
Hi!  The title and the screenshot say it all, really-- I tried using the XY to Line tool to generate lines between two sets of coordinates.  Some of them went fine, and for some of them, I got...this mess?  Most of the lines should end within the confines of Greece, not go arcing off into the wild blue yonder.  Any troubleshooting tips?
HarryHattusa
I figured out the problem, and it was in the input data.  Could a mod delete this thread so nobody wastes their time on it?
HarryHattusa
DavidPike
MVP Frequent Contributor
What coordinate system are you using, and what coordinate system are the points in?
It's likely incorrect coordinates supplied or the wrong coordinate system/projection being used in the tool environment settings or a mismatch of both.
