What does SingleKey refer to when building address locator?
942
12-20-2019 09:12 AM
JotHall1
While building address locators to eventually use in a composite locator I keep seeing the term SingleKey.  Can someone explain to me what it actually is?  Does it just refer to the attribute field the locator was built off?  If not, should I replace the SingleKey field with the actual field(s) I want to use for input mapping and input address fields? Any clarification would be help as I cannot find any ESRI reference material describing SingleKey.
Thanks!
Jot
Ranga_Tolapi
Following
