Warning 000970, attribute index issue; help please!
3274
08-07-2013 11:20 AM
MattDawson
Working in model builder (beginner) , trying to update/ combine two attribute tables, however I cannot continue to work due to:
"Warning 000970" It states I must add an "attribute index" however after adding it to the appropriate areas I am still encountering this issue. I have searched forums far and wide and have tried just about everything. Anyone there have any suggestions?
I am working out of 10.1 and am at a complete dead end.
Matt
DaleHoneycutt
This is just a warning, meaning that the tool/model will still execute, it just will execute slower than if you had an index.
If you added an attribute index but are still getting a warning in ModelBuilder, it may be because you need to validate the model (the icon with the checkmark on it, or from the Model Menu, choose Validate).  When in a ModelBuilder session, ModelBuilder isn't aware of changes to data you make outside of ModelBuilder.  That's what validate does -- refreshes all the data and variables.
If this doesn't do the trick, then the only thing I can think of is that you didn't create the index on the right dataset.
