Use Field Calculator to strip out "1/2" in an Address
2927
03-18-2015 07:30 AM
BrianO_keefe
Honored Contributor
I'm busy processing 200,000+ addresses that incorrectly have an old outdated sub-designation in use. Our City no longer uses the "1/2" in our addresses. We have updated them to a sub-designation of "REAR" instead.
So whereas previous an address might have been "1234-1/2 East Main Street South" it is now listed as "1234 East Main Street South Rear" and I am trying to use the Field Calculator to remove this.
Here is my code.
DIM StripStart, StripEnd
DIM DataToStrip, DataToStripRight, DataToStripLeft, DataToStripLen
DIM WhatToStrip, WhatToStripLen
DIM NewDataSet
WhatToStrip = '1/2'
WhatToStripLen = Len( WhatToStrip )
DataToStrip = [Address]
DataToStripLen = Len( DataToStrip )
StripStart = InStr( 1, DataToStrip, WhatToStrip )
StripEnd = StripStart + WhatToStripLen
DataToStripRight = Right( DataToStrip, ( DataToStripLen - StripEnd ) )
DataToStripLeft = Left( DataToStrip, StripStart )
NewDataSet = DataToStripLeft + ' ' + DataToStripRight
I am getting a 999999 error that says it is undefined. Can anyone take a look at this and see what I'm doing wrong?
Message was edited by: Brian O'keefe Cleaned up the Code. It has compiled into a single line due to missing BR tags.
BrianO_keefe
Honored Contributor
I figured it out. It has to do with the TYPE of VB used in the Field Calculator.
The apostrophe ' that I was using signified a COMMENT not a VARIABLE or VALUE.
Here is the corrected finished code for stripping out a subsection of text from a text field.
DIM NewDataSet
' Example address provided
' 1003 1/2 N EVANSTON AVE
WhatToStrip = "1/2"
WhatToStripLen = Len( WhatToStrip )                         ' = 3
DataToStripLen = Len( DataToStrip )                         ' = 23
StripStart = InStr( 1, DataToStrip, WhatToStrip )     ' = 6
StripEnd = StripStart + WhatToStripLen                    ' = 9
DataToStripLeft = Left( DataToStrip, ( StripStart - 1 ) )
' 1003 N EVANSTON AVE
NewDataSet = DataToStripLeft + DataToStripRight
I added in the comments to help explain the code.
BrianO_keefe
Honored Contributor
DIM NewDataSet
WhatToStrip = "1/2"
