Transform from NAD_1983_HARN to WGS_1984
1125
12-20-2019 09:40 AM
RobertStevens
I have a number of featureclasses using the projected coordinate system
   NAD_1983_HARN_StatePlane_Oregon_North_FIPS_3601_Feet_Intl
which uses as a geographic coordinate system (GCS)
   NAD_1983_HARN
I am trying to convert these  using the Project tool in the ArcMap toolbox
to
   WGS_1984_Web_Mercator_Auxiliary_Sphere based on GCS_WGS_1984
When I use the tool it suggests using the transformation named
  NAD_1983_HARN_To_WGS_1984_2
In ESRI's documentation (https://support.esri.com/en/Technical-Article/000005929)
it says never to use the transformation
   NAD_1983_To_WGS_1984_2
It is a bit confusing. These two transformations, one from 1983_HARN, the other without the _HARN in the name,
are they completely different transforms? Is that the best transformation to use in Oregon, North?
MelitaKennedy
Esri Notable Contributor
Completely different transformations. NAD 1983 HARN is a re-adjustment (improvement) of NAD 1983. NAD_1983_To_WGS_1984_2 is not recommended because its area of use is for the Aleutian Islands. I think I've seen specific Aleutian Island data once or maybe twice in the 25 years I've worked at Esri.
Use NAD_1983_HARN_To_WGS_1984_3 over NAD_1983_HARN_To_WGS_1984_2.
Melita
MelitaKennedy
Melita
RobertStevens
Ty Melita. That is most helpful.
