Tool 'Times' won't accept rasters selected by iteration
594
10-24-2019 02:19 AM
JulijanKodric
Hello dear community, I have a problem I don't know how to overcome while trying to design a submodel that would iterate several rasters by means of specified tools.
As you may see from the appended screenshot, I've put up a raster iterator that should seize all the rasters from the designated database. The problem arises, when the selected raster (frost_oe) enters into the rest of the model - the tool Times shows "ERROR 000964" for some reason, claiming that the to be multiplied raster datasets (frost_oe and hws_2012) don't overlap each other. That cannot be the case because in the fact they do, and if I connect both rasters without one coming out as a product of iteration, the tool works perfectly fine and accepts both without complaint.
How can I overcome this problem?
I would be very thankful for your suggestions!
Julijan
DuncanHornby
MVP Notable Contributor
I've just created a dummy model with an iterator and Times tool and it worked for me.
So maybe is a genuine different in your extents? I would look at the raster properties, compare number of rows/columns/cell size/extent.
